查看: 425|回复: 0
TPS2071EVM-159评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 16:15:10 | 显示全部楼层 |阅读模式
    TPS2071EVM-159评估模块提供了一种评价使用TPS2071 USB集线器电源控制器的混合动力车(bus-powered/self-powered)毂的性能的简便方法。一个完整的设计和测试,USB集线器呈现。该中心是一个可以提供高达0.5 A的连续输出电流在自供电模式或高达0.1的EVM A的连续输出电流在总线供电模式。
    • Bus-powered input voltage range (BP), 0 to 100 mA/port, 4.75 V min to 5.25 V max
    • Self-power input voltage range (SP), 0 to 500 mA/port, 4.85 V min to 5.15 V max
    • Downstream output voltage range in bus-powered mode, 0 to 100 mA/port, 4.4 V min to 5.25 V max
    • Downstream output voltage range in self-powered mode, 0 to 500 mA/port, 4.75 V min to 5.15 V max
    • Output current range, bus-powered, 0 to 0.1 A
    • Output current range, self-powered, 0 to 0.5 A
    • Output current limit, bus-powered, 0.15 A typical
    • Output current limit, self-powered, 0.90 A typical
    • Output Voltage: DC 5V +/- 3 %
    • Max. Output Current: 2 A or up
    • Connector: 2.1 mm (0.8 inch) diameter, female connector, positive center/inner ring polarity
    • AC Adapter Recommendation: WA15-050-13/1 from VENTRON
    The TPS2071EVM-159 Evaluation Module provides a convenient method for evaluating the performance of a hybrid (bus-powered/self-powered)hub using the TPS2071 USB Hub Power Controller. A complete designed and tested USB hub is presented. The hub is an EVM that can deliver up to 0.5 A of continuous output current in self-powered mode or up to 0.1 A of continuous output current in bus-powered mode. AC Adapter NOT included Features
    • Complete 4-Port Hub Reference Design featuring TPS2071 USB Power Controller and TUSB2046B USB Device Controller.
    • Smaller, simpler, and more cost-effective design due to advanced integration of TPS2071
    TPS2070/71.pdf
    907.75 KB, 下载次数: 0
    TPS2071EVM-159 Users Guide.pdf
    836.89 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:31 , Processed in 0.110943 second(s), 16 queries , MemCache On.
