查看: 383|回复: 0
SN65HVD101评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 15:24:16 | 显示全部楼层 |阅读模式
    SN65HVD101评估模块的IO-Link物理层实现的IO-Link接口,用于工业点至点的通讯。DescriptionThe SN65HVD101 and SN65HVD102 IO-LINK PHYs implement the IO-LINK interface for industrial point-to-point communication. When the device is connected to an IO-Link master through a 3-wire interface, the master can initiate communication and exchange data with the remote node while the SN65HVD10X acts as a complete physical layer for the communication.Features
    • Configurable CQ output:
    • push-pull, high-side or low-side for SIO mode
    • 9V to 36V Supply range
    • Configurable 3.3V/5V Integrated LDO (HVD101 only)
    • Reverse polarity protection
    • Power Good indicator
    • Over-temperature protection
    • Current Limit indicator
    • Remote Wake-up indicator
    SN65HVD101/102.pdf
    915.02 KB, 下载次数: 0
    SN65HVD101/102 EVM Guide.pdf
    430.7 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:27 , Processed in 0.113377 second(s), 16 queries , MemCache On.
