查看: 301|回复: 0
ISO71XXDBQ评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 15:16:04 | 显示全部楼层 |阅读模式
    ISO71XXDBQ是低功耗数字隔离器评估模块。该ISO71XXDBQ-EVM附带焊接下来ISO7131CCDBQ设备。用户可以删除该设备和焊接下来4通道ISO714XCCDBQ设备中的任何一个。描述The ISO71XXDBQ-EVM comes with the ISO7131CCDBQ device soldered down. The user can remove this device and solder down any one of the 4-channel ISO714XCCDBQ devices. This EVM allows the user to evaluate the isolator performance and parameters. For safety reasons tThe EVM is not designed to work at voltages above 5.5-V. The EVM should not be used for high-voltage isolation testing. Please observe the cautions described in the EVM user's guide. 特性User configurable for use with triple- and quad-channel ISO71xx isolatorsEnables opposing channel testing with the ISO7131, ISO7141, and ISO7142Same direction evaluation can be performed using the ISO7140User configurable load options for the input and output channels
    ISO71xxCC.pdf
    477.18 KB, 下载次数: 0
    ISO71XX-EVM User Guide.pdf
    1.32 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:37 , Processed in 0.115823 second(s), 16 queries , MemCache On.
