查看: 581|回复: 0
BQ2026评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 14:45:42 | 显示全部楼层 |阅读模式
    该bq2026评估板和bq2026EVM评估软件的目的是为了演示bq2026的功能。该bq2026评估板同时支持bq2026DBZR(SOT-23)和bq2026LPR(TO-92)封装,但只有一个包可以被评估/在任何时间进行编程。该bq2026是理想的应用,如电池组配置参数,记录维护,资产跟踪,产品修正状态和访问代码的安全性。DescriptionThe purpose of the bq2026 evaluation board and the bq2026EVM evaluation software is to demonstrate the functionality of the bq2026. The bq2026 evaluation board supports both the bq2026DBZR (SOT-23) and bq2026LPR (TO-92) packages but only one package can be evaluated / programmed at any time. The bq2026 is a 1.5K-bit serial EPROM containing a factory-programmed, unique 48-bit identification number, 8-bit family code, and a 64-bit status register. The bq2026 is ideal for applications such as battery pack configuration parameters, record maintenance, asset tracking, product revision status, and access-code security.Evaluation kit Contains:bq2026EVM REVA board with one bq2026DBZR package installed in the socket. (bq2026LPR samples can be ordered at www.ti.com)PC interface board EV2300USB Cable (Type A-B)Features
    • Demonstrate the functionality of bq2026
    • Support programming capability for bq2026
    • Support for both SOT-23 and TO-92 packages
    bq2026.pdf
    676.39 KB, 下载次数: 0
    BQ2026EVM.pdf
    380.41 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:36 , Processed in 0.119853 second(s), 16 queries , MemCache On.
