查看: 971|回复: 0
USB TLV320AIC3254评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 14:17:00 | 显示全部楼层 |阅读模式
    该TLV320AIC3254EVM-U是一个USB音频设备,具有可编程的输入和输出,拥有效果丰富的路由功能。这是一个简单的平台来评估TLV320AIC3254的miniDSP音频编解码器。该TLV320AIC3254EVM-U软件,该AIC3254EVM-U CS,是一个直观的,易于使用;功能强大的工具来学习,评估和控制TLV320AIC3254。The TLV320AIC3254EVM-U is a USB Audio Device with programmable inputs and outputs, effects and extensive routing capabilities. It is a simple platform to evaluate the TLV320AIC3254 miniDSP Audio Codec. The TLV320AIC3254EVM-U software, the AIC3254EVM-U CS, is an intuitive, easy-to-use, powerful tool to learn, evaluate and control the TLV320AIC3254.Software development for the TLV320AIC3254 is supported through TI's comprehensive PurePath Studio Development Environment. A powerful, easy-to-use tool designed specifically to simplify software development on the TLV320AIC3xxx miniDSP audio platform. The Graphical Development Environment includes a library of common audio functions that can be dragged-and-dropped into an audio signal flow and graphically connected together. The DSP code is assembled from the graphical signal flow. Features
    • Small USB Stick form factor EVM for the TLV320AIC3254 Audio Codec.
    • USB connection to the PC provides power, control and streaming audio for easy evaluation.
    • Pre-programmed EEPROM boots the TLV320AIC3254 as a fully functional USB Audio Device when connected to a PC.
    • Easy to use AIC3254 Control Software (CS) configures and controls the TLV320AIC3254.
    TLV320AIC3254.pdf
    1.06 MB, 下载次数: 0
    TLV320AIC3254EVM-U User Guide.pdf
    6.82 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:34 , Processed in 0.111356 second(s), 16 queries , MemCache On.
