查看: 991|回复: 0
INA282-286评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 14:07:45 | 显示全部楼层 |阅读模式
    INA282-286评估模块旨在提供该系列器件的基本功能评估。该INA282-286EVM允许用户安装一个分流电阻,然后连接两个共模电压和负载,来开发输入电压;或者省略该分流电阻器,并直接施加差分电压到器件的输入。这种灵活性允许用户测试在模拟方式的设备下操作。The INA282-286EVM is intended to provide basic functional evaluation of this device family. The fixture layout is not intended to be a model for the target circuit, nor is it laid out for electromagnetic compatibility (EMC) testing. The INA282-286EVM allows the user to install a shunt resistor, and then connect both the common-mode voltage and load to develop the input voltage, or omit the shunt resistor and apply a differential voltage directly to the device input. This flexibility allows a user to test the device operation in a simulated manner as well as an actual application. Features
    • Easy handling of the small MSOP package
    • Easy access to all device pins
    • Space for optional input filtering capacitors and resistors as well as a prototype area for additional user defined circuitry
    • Space for shunt resistors of various footprints
    • Evaluation of all gain options through provided device boards as well as a location to solder a test device directly onto the board
    INA282(3,4,5,6,).pdf
    1.18 MB, 下载次数: 0
    INA282-286EVM User Guide.pdf
    1.85 MB, 下载次数: 0
    GMT+8, 2024-11-25 21:52 , Processed in 0.113814 second(s), 16 queries , MemCache On.
