查看: 287|回复: 0
ISO1050评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 14:01:06 | 显示全部楼层 |阅读模式
    ISO1050评估模块设计为ISO1050分离CAN收发器的评估。输入和输出连接,以及用于测量的测试点,可帮助设计人员使用该设备,是世界上第一个CAN收发器集成了隔离。This multi-functional EVM is designed for the evaluation of the ISO1050 isolated CAN transceiver. Input and output connections, as well as test points for measurements, are provided to help designers use this device, the world's first CAN transceiver with integrated isolation. Features
    • 4000-VPEAK Isolation
    • Failsafe Outputs
    • Low Loop Delay: 150 ns Typical
    • 50 kV/us Typical Transient Immunity
    • Meets or Exceeds the Requirements of ISO 11898
    • Bus-Fault Protection of -27 V to 40 V
    • Dominant Time-Out Function
    • UL 1577, IEC 60747-5-2 (VDE 0884, Rev.2), IEC 61010-1, IEC 60950-1 and CSA Approval Pending
    • 3.3-V Inputs are 5-V Tolerant
    ISO1050.pdf
    1.32 MB, 下载次数: 0
    ISO1050EVM User Guide.pdf
    1.14 MB, 下载次数: 0
    GMT+8, 2025-1-4 07:02 , Processed in 0.121351 second(s), 17 queries , MemCache On.
