查看: 375|回复: 0
SN65HVD255D评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 13:54:01 | 显示全部楼层 |阅读模式
    SN65HVD255D评估模块配备了SN65HVD255 CAN收发器安装工厂。该EVM具有配置基本的CAN评估,需要评估各种负载和终端设置CAN收发器的性能。DescriptionThe EVM comes with the SN65HVD255 CAN transceiver factory installed. The CAN EVM may be reconfigured by a user for use with all TI CAN transceiver families: SN65HVD23x, SN65HVD25x, SN65HVD10x0 and SN65HVDA54x by replacing the transceiver and setting jumpers on the EVM. The EVM has configurations for basic CAN evaluation, various load and termination settings necessary to evaluate CAN transceiver performance. Features
    • Meets the requirements of ISO11898-2
    • “Turbo CAN”:
    • short propagation delay times and fast loop times
    • higher data rates in network
    • enhances system timing margins
    • I/O Voltage Range Supports 3.3V and 5V MCUs
    • Ideal passive behavior when unpowered
    • Bus pins are high impedance (no load to operating bus)
    • Logic pins are high impedance
    • Power up / down with glitch free operation on bus
    • Protection Features:
    • ESD Protection of Bus Pins
    • HBM ESD Protection Exceeds ±12 kV
    • Bus Fault Protection -27V to 40V
    • Under voltage protection on supply pins
    • TXD (Driver) dominant time out (DTO)
    • Thermal Shutdown Protection
    • Characterized for –40°C to 125°C Operation
    SN65HVD255.pdf
    936.81 KB, 下载次数: 0
    CAN EVM User Guide.pdf
    1.21 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:46 , Processed in 0.100275 second(s), 16 queries , MemCache On.
