查看: 258|回复: 0
INA210-214评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-11 13:41:09 | 显示全部楼层 |阅读模式
    INA210-214EVM旨在提供该系列器件的基本功能评估。The INA210-214EVM is intended to provide basic functional evaluation of this device family. The fixture layout is not intended to be a model for the target circuit, nor is it laid out for electromagnetic compatibility (EMC) testing The INA210-214EVM allows the user to install a shunt resistor, and then connect both the common-mode voltage and load to develop the input voltage, or omit the shunt resistor and apply a differential voltage directly to the device input. This flexibility allows a user to test the device operation in a simulated manner as well as an actual application. FeaturesEasy handling of the small SC70 packageEasy access to all device pinsSpace for optional input filtering capacitors and resistors as well as a prototype area for additional user defined circuitrySpace for shunt resistors of various footprintsEvaluation of all gain options through provided device boards as well as a location to solder a test device directly onto the board
    INA210-214.pdf
    1.24 MB, 下载次数: 0
    INA210-214EVM Guide.pdf
    3.38 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:42 , Processed in 0.112653 second(s), 16 queries , MemCache On.
