查看: 172|回复: 0
BQ24100EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-11 13:35:00 | 显示全部楼层 |阅读模式
    BQ24100EVM评估模块(EVM)为BQ24100锂离子充电管理IC。该BQ24100是一个高度集成的电池充电IC,利用同步开关模式,电源转换为单节锂离子电池,进行全面高效的充电控制。该EVM是一个完整的基于BQ24100电路,也提供了一个方便的方法来评估IC的操作和性能。DescriptionThe Texas Instruments bq24100EVM is the evaluation module (EVM) for the bq24100 Li-Ion charge management IC. The bq24100 is a highly integrated battery charge IC utilizing synchronous switch mode power conversion for efficient and comprehensive charge control of a single cell Li-Ion battery. The EVM is a complete bq24100 based circuit and provides a convenient method to evaluate the operation and performance of the IC.The EVM is set up at the factory to charge at 1.33A and a 4.2V voltage limit.The EVM development tool includes a tested evaluation module; a user guide (SLUU200) that contains the schematic, bill of materials, component placement, layout and the setup of the EVM; and the bq24100 data sheet.The only necessities to use the EVM are a power source (16V max) and the battery to be charged.Features
    • Input voltage: 5V to 16V
    • Charge rate: 1.33A
    • Output regulation voltage: 4.2V
    • Number of series cells: 1
    BQ2410x(A), 11x(A).pdf
    1.26 MB, 下载次数: 0
    BQ241xx Guide.pdf
    399.11 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:41 , Processed in 0.103007 second(s), 16 queries , MemCache On.
