查看: 284|回复: 0
ISO722X评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-11 13:26:38 | 显示全部楼层 |阅读模式
    ISO722X评估模块(EVM)是用于测试参数,并安装的ISO7421双通道隔离器。该EVM可以让用户对与任何ISO7220X,ISO7221X或ISO742X双通道隔离器的用途进行重新配置。DescriptionThis evaluation module (EVM) is used for testing the parametrics of the factory installed ISO7421 dual channel isolator. The EVM may be reconfigured by the user for use with any of the ISO7220X, ISO7221X or ISO742X dual channel isolators. Features1,5,25 and 150-Mbps Signaling Rate Options-Low Channel-to-Channel Output Skew; 1 ns max -Low Pulse Width Distortion (PWD); 1 ns max -Low Jitter Content: 1 ns Typ at 150Mbps Typical 25 Year life at Rated Voltage4000Vpeak Isolation, 560Vpeak Viorm- UL 1577, IEC 60747-5-2 VDE 0884, Rev 2), IEC 61010-1, IEC 60950-1 and CSA Approved - 50KV/us Typical Transient Immunity Operates with 3.3V of 5V supplies4KV ESD ProtestionHigh Elecrtromagnetic Immunity-40 C to 125 C Operating Range
    ISO7220,21A,B,C,M.pdf
    1.15 MB, 下载次数: 3
    ISO722xEVM User Guide.pdf
    433.14 KB, 下载次数: 1
    GMT+8, 2025-1-15 23:35 , Processed in 0.105311 second(s), 16 queries , MemCache On.
