查看: 243|回复: 0
BQ20Z65评估模块
  • 签到天数: 361 天
    发表于 2014-3-10 17:27:49 | 显示全部楼层 |阅读模式
    此评估模块(EVM)是为bq20z65/bq29412电池管理系统的完整评估系统。该EVM包含一个bq20z65/bq29412电路模块和一个链接到基于Windows™的PC软件。DescriptionThis evaluation module (EVM) is a complete evaluation system for the bq20z65/bq29412 battery management system. The EVM includes one bq20z65/bq29412 circuit module and a link to Windows™-based PC software. The circuit module includes one bq20z65 integrated circuit (IC), one bq29412 IC, and all other onboard components necessary to monitor and predict capacity, perform cell balancing, monitor critical parameters, protect the cells from overcharge, over-discharge, short-circuit, and overcurrent in 2-, 3- or 4-series cell Li-ion or Li-polymer battery packs. The circuit module connects directly across the cells in a battery. With the EV2300 interface board and software, the user can read the bq20z65 data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq20z65/bq29412 solution under different charge and discharge conditions. Features
    • Complete evaluation system for the bq20z65 SBS 1.1-compliant advanced gas gauge with Impedance Track™ technology and bq29412 independent overvoltage protection IC
    • Populated circuit module for quick setup
    • Software that allows data logging for system analysis
    BQ20Z65-R1.pdf
    632.51 KB, 下载次数: 0
    BQ20Z65EVM-001 User Manual.pdf
    1.2 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:32 , Processed in 0.108403 second(s), 16 queries , MemCache On.
