查看: 320|回复: 0
BQ34Z100评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-10 17:22:17 | 显示全部楼层 |阅读模式
    BQ34Z100评估模块(EVM)是以bq34z100为基础的广泛电量计的锂离子化学的完整评估系统。该电路模块包含一个bq34z100集成电路(IC)和必要的监测和预测能力在1个或多个串联锂离子,锂聚合物,磷酸铁锂或电池组的所有其他组件。该电路模块直接连接在电池两端。This evaluation module (EVM) is a complete evaluation system for the bq34z100 wide range fuel gauge for lithium ion chemistries when combined with an EV2300 USB adapter and Windows™-based PC software downloadable from the TI.com website.The circuit module includes one bq34z100 integrated circuit (IC) and all other components necessary to monitor and predict capacity in 1 or more series cell Li-ion, Li-polymer, or LiFePO4 battery packs. The circuit module connects directly across the battery.With the EV2300 interface adapter and software, it is possible to read the bq34z100 data registers,program the chip for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq34z100 solution under different charge and discharge conditions.
    BQ34Z100.pdf
    1.04 MB, 下载次数: 0
    BQ34Z100EVM User Guide.pdf
    1.09 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:41 , Processed in 0.108814 second(s), 16 queries , MemCache On.
