查看: 376|回复: 0
TUSB9261演示板
  • 签到天数: 361 天
    发表于 2014-3-10 17:15:24 | 显示全部楼层 |阅读模式
    TUSB9261演示板是一个独立的参考设计,作为一个超高速USB(USB3.0)总线和串行ATA(SATA)设备之间的桥梁。该TUSB9261 DEMO用于评估系统的兼容性。它提供了一个TUSB9261硬件参考设计,用于连接SATA设备,例如固态驱动器,硬盘驱动器,DVD驱动器或蓝光光驱。The TUSB9261DEMO board is a free-standing reference design that acts as a bridge between a SuperSpeed USB (USB 3.0) bus and a Serial–ATA (SATA) device. The TUSB9261DEMO is used to evaluate system compatibility. It provides a TUSB9261 hardware reference design for connection to a SATA device such as a solid state drive, hard disk drive, DVD drive, or Blu-Ray drive. The included firmware is capable of supporting a single SATA drive and supports the following:USB Attached SCSI (UAS)USB Mass Storage Class (MSC) Bulk-Only Transport (BOT) including the 13 error cases.USB Mass Storage Specification for BootabilityUSB Device Class Definition for Human Interface Devices (HID) for firmware update and manufacturer-specific custom functionalitySerial ATA Advanced Host Controller Interface (AHCI)General Purpose Input/Output (GPIO)Pulse Width Modulation (PWM) for LED dimming controlSerial Peripheral Interface (SPI) for updating firmware and loading custom device descriptorsSerial Communications Interface (SCI) for debug output onlyThe board works with the LINUX, MAC, and Windows native Mass Storage Class Drivers.Features
    • A free-standing external storage reference design
    • Auto-detection of single SATA drive
    • USB Attached SCSI Protocol Class Support
    • Bulk Only Transport Class Support
    The DEMO board as supplied is intended to operate as a USB bus-powered peripheral with solid-state-drives. In order to use the DEMO board with higher current devices such as hard drives or optical drives, an external power supply is required. More information on the requirements for this external power jack is found in the User's Guide.
    TUSB9261.pdf
    275.71 KB, 下载次数: 0
    TUSB9261 Demo Board Guide.pdf
    914.7 KB, 下载次数: 0
    Analog Signal Chain Guide.pdf
    5.86 MB, 下载次数: 1
    GMT+8, 2025-1-15 23:24 , Processed in 0.117405 second(s), 16 queries , MemCache On.
