查看: 411|回复: 0
UCC28019评价法模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-10 16:51:23 | 显示全部楼层 |阅读模式
    UCC28019评价法模块(EVM)是一个350瓦的离线功率因数校正(PFC)升压转换器,提供了一个390 V稳压输出0.9 A的负载电流。该PFC转换器可容纳85 VAC的输入电压,范围为265 VAC和采用平均电流模式控制,在65 kHz的固定频率。该UCC28019采用了多种保护功能,确保系统安全运行。DescriptionThe UCC28019 evaluaton module (EVM) is a 350 Watt off-line power factor correction (PFC) boost converter providing a 390 V regulated output at 0.9 A of load current. The PFC converter accommodates an input voltage range of 85 VAC to 265 VAC and uses average current mode control at a fixed frequency of 65 kHz. The UCC28019 incorporates a wide range of protection features to ensure safe system operation. Features
    • 350 W, 390 V output
    • Universal off-line input voltage range
    • Average current mode PWM control
    • Fixed 65 kHz oscillator frequency
    • Cycle-by-cycle peak current limiting
    • VCC under voltage lockout
    • Voltage regulation open loop detection
    • Output under-voltage protection
    • Output over-voltage protection
    • AC input brown-out protection
    • Enhanced dynamic response
    • Soft-start
    UCC28019.pdf
    1012.01 KB, 下载次数: 0
    UCC28019EVM Guide.pdf
    409.04 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:20 , Processed in 0.122127 second(s), 16 queries , MemCache On.
