查看: 351|回复: 0
BQ24103A评估模块
  • 签到天数: 361 天
    发表于 2014-3-10 16:19:04 | 显示全部楼层 |阅读模式
    BQ24103A评估模块提供了对使用BQ241xx产品系列便携式应用的充电管理解决方案的一种评价。该充电器旨在提供高达2.0 A的连续输出电流。该充电器是由提供的充电电流1.33 A中的系数进行编程。DescriptionThe Evaluation Module provides a convenient method for evaluating the performance of a charge management solution for portable applications using the BQ241xx product family. A complete designed and tested charger is presented. The charger is designed to deliver up to 2.0 A of continuous output current. The charger is programmed from the factor to deliver 1.33 A of charging current. Follow the instructions in the User Guide that pertain to the specific BQ241xxEVM (one-, two- or three-cell) to be evaluated. See the BQSWITCHER data sheet (SLUS606) prior to evaluation for detailed information on the BQSWITCHER device.
    BQ241xx Guide.pdf
    399.11 KB, 下载次数: 0
    BQ24100/3-5/8-9/13/15 (A).pdf
    1.26 MB, 下载次数: 0
    GMT+8, 2025-1-16 00:14 , Processed in 0.117294 second(s), 16 queries , MemCache On.
