查看: 267|回复: 0
TS3USB221A评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-10 15:59:26 | 显示全部楼层 |阅读模式
    TS3USB221AEVM是德州仪器的高速USB2.0(480 Mbps的)1:2多路复用器/解复用器开关的评估模块。该评估模块演示了低bit-to-bit歪斜,高通道至通道噪声隔离,并与各种标准,如高速USB2.0(480 Mbps)的相容性,即使用在TS3USB221A时可能高高速信号的应用。The TS3USB221AEVM is an evaluation module for the Texas Instruments high-speed USB 2.0 (480-Mbps) 1:2 multiplexer/demultiplexer switch. The USB221AEVM allows signals to pass with minimum edge and phase distortion, integrates ESD protection cells on all pins, and also multiplexes differential signals from a common USB input to one of two corresponding outputs. This evaluation module demonstrates the low bit-to-bit skew, high channel-to-channel noise isolation, and compatibility with various standards, such as high-speed USB 2.0 (480 Mbps), that is possible when using the TS3USB221A in high-speed signaling applications.
    TS3USB221A.pdf
    1.11 MB, 下载次数: 0
    TS3USB221/A/E EVM Guide.pdf
    314.24 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:16 , Processed in 0.110511 second(s), 16 queries , MemCache On.
