查看: 261|回复: 0
TPS2543EVM-064评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-10 15:51:38 | 显示全部楼层 |阅读模式
    TPS2543EVM-064评估模块(EVM)可帮助设计人员评估TPS2543 USB充电端口电源开关和控制器的性能。该EVM包含输入和输出接口。还提供了跳线控制,以减轻设备功能评估。DescriptionThe Texas Instruments TPS2543EVM-064 evaluation module (EVM) helps designers evaluate the performance of the TPS2543 USB Charging Port Power Switch and Controller. The EVM contains input and output connectors. Jumper controls are also provided to ease evaluation of device features. Features
    • Adjustable, current-limited power distribution switches with charging detection
    • Screw jack type input and output connectors
    • Jumper for device enable input
    TPS2543.pdf
    1.53 MB, 下载次数: 0
    TPS2543EVM User Guide.pdf
    292.99 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:18 , Processed in 0.104009 second(s), 16 queries , MemCache On.
