查看: 327|回复: 0
TPS7A3501EVM-547评估模块
  • 签到天数: 361 天
    发表于 2014-3-10 14:43:24 | 显示全部楼层 |阅读模式
    TPS7A3501EVM-547评估模块(EVM)基于TPS7A3501来参考设计,进行低噪声,高PSRR,1-A有源滤波器的工程示范和评估。DescriptionThe Texas Instruments TPS7A3501EVM-547 evaluation module (EVM) is a fully assembled and tested circuit for evaluating the TPS7A3501 Low Noise, High PSRR 1A Active Filter. The EVM circuit is configured to be a reference design for engineering applications requiring current to a dynamic load of up to 1A. Connectors and test points are provided for convenience.Features
    • Low Noise Output: 10μV rms 10Hz to 1MHz
    • Wide-Bandwidth High PSRR: 60dB at 10kHz, 47dB at 1MHz
    • Low VIN to VOUT Voltage Delta: Fixed 300mV @ 0 to 1A
    • ±40mV Overall Accuracy on Voltage Delta
    • Wide VIN range: 1.71V to 5.55V
    • Stable with 10.0μF ceramic output capacitor
    • Current Limit and Thermal Shutdown for Fault Protection
    TPS7A3501EVM-547 User Guide.pdf
    234.58 KB, 下载次数: 0
    TPS7A3501.pdf
    1.32 MB, 下载次数: 0
    GMT+8, 2025-1-29 03:11 , Processed in 0.104422 second(s), 16 queries , MemCache On.
