查看: 294|回复: 0
MDL-BLDC电机控制电路板
  • 签到天数: 361 天
    发表于 2014-3-10 14:31:08 | 显示全部楼层 |阅读模式
    MDL-BLDC电机控制电路板是由三个通信的一个控制接口,或通过一个简单的模拟控制电压。主要功能包括:完整的CAN和以太网通信接口,32位Stellaris®LM3S8971微控制器,以及先进的软件在不同控制范围内来优化电机的应用。The brushless DC (BLDC) motor control board is a four-quadrant motor control board for three-phase BLDC motors rated at up to 36 V (see Figure 1). Key features include complete CAN and Ethernet communications interfaces, the powerful, 32-bit Stellaris®LM3S8971 microcontroller, and sophisticated software to optimally control a range of motors in diverse applications.10/100 Ethernet connects the BLDC module to an array of networks—from dedicated industrial networks to the internet. The standard BLDC module includes the Stellaris motor control and configuration (MCC) protocol. This protocol can be replaced with any industry-standard protocol.The MDL-BLDC motor control board is controlled by one of the three communication interfaces, or by a simple analog control voltage. Figure 3 shows power, motor, and peripheral connections to the main terminal block. Connections to the Hall sensors, analog speed control potentiometer, and quadrature/incremental encoder are all optional.
    MDL-BLDC.pdf
    320.92 KB, 下载次数: 1
    GMT+8, 2025-1-16 00:25 , Processed in 0.146388 second(s), 16 queries , MemCache On.
