查看: 188|回复: 0
EV- VN5016AJ评估板
  • 签到天数: 361 天
    发表于 2014-3-7 14:13:50 | 显示全部楼层 |阅读模式
    EV- VN5016AJ评估板来预装配有VN5016AJ -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VN5016AJ provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VN5016AJ-E high-side driver.The VN5016AJ-E is a monolithic device made using STMicroelectronics®VIPower®M0-5 technology. It is intended for driving resistive or inductive loads with one side connected to ground.Active VCCpin voltage clamp protects the device against low energy spikes. This device integrates an analog current sense which delivers a current proportional to the load current (according to a known ratio) when CS_DIS is driven low or left open. When CS_DIS is driven high, the CURRENT SENSE pin is in a high impedance condition.Output current limitation protects the device in overload condition. In case of long overload duration, the device limits the dissipated power to safe level up to thermal shutdown intervention. Thermal shutdown with automatic restart allows the device to recover normal operation as soon as fault condition disappears.
    VN5016AJ-E.pdf
    384.12 KB, 下载次数: 0
    EV-VN5016AJ Brief.pdf
    140.97 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:02 , Processed in 0.112502 second(s), 16 queries , MemCache On.
