查看: 269|回复: 0
EV- VN5E050AJ评估板
  • 签到天数: 361 天
    发表于 2014-3-7 14:08:12 | 显示全部楼层 |阅读模式
    EV- VN5E050AJ评估板预装配有VN5E050AJ -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VN5E050AJ provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VN5E050AJ-E high-side driver.The VN5E050AJ-E is a single channel high-side driver manufactured using ST proprietary VIPower M0-5 technology and housed in PowerSSO-12 package. The VN5E050AJ-E is designed to drive 12V automotive grounded loads, providing protection, diagnostics and easy 3 V and 5 V CMOS-compatible interface with any microcontroller.The device integrates advanced protective functions such as load current limitation, inrush and overload active management by power limitation, overtemperature shut-off with auto-restart and overvoltage active clamp. A dedicated analog current sense pin is associated with every output channel provides enhanced diagnostic functions including fast detection of overload and short-circuit to ground through power limitation indication, overtemperature indication, short-circuit to VCCdiagnosis and ON-state and OFF-state open-load detection.The current sensing and diagnostic feedback of the whole device can be disabled by pulling the CS_DIS pin high to share the external sense resistor with similar devices.
    VN5E050AJ-E.pdf
    422.02 KB, 下载次数: 0
    EV-VN5E050AJ Brief.pdf
    141.09 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:10 , Processed in 0.105593 second(s), 16 queries , MemCache On.
