查看: 244|回复: 0
EV- VND5T100AJ评估板
  • 签到天数: 361 天
    发表于 2014-3-7 14:03:43 | 显示全部楼层 |阅读模式
    EV- VND5T100AJ评估板来预装配有VND5T100AJ -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VND5T100AJ provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VND5T100AJ-E high-side driver.The VND5T100AJ-E is a monolithic device made using STMicroelectonics®VIPower®technology, intended for driving resistive or inductive loads with one side connected to ground.Active VCCpin voltage clamp protects the device against low energy spikes. This device integrates an analog current sense which delivers a current proportional to the load current.Fault conditions such as overload, overtemperature or short to VCCare reported via the current sense pin. Output current limitation protects the device in overload condition. The device latches off in case of overload or thermal shutdown. The device is reset by a low level pass on the fault reset standby pin.A permanent low level on the inputs and fault reset standby pin disables all outputs and sets the device in standby mode.
    VND5T100AJ-E.pdf
    592.16 KB, 下载次数: 0
    EV-VND5T100AJ Brief.pdf
    141.55 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:21 , Processed in 0.113053 second(s), 16 queries , MemCache On.
