查看: 233|回复: 0
EV- VND5E025AK评估板
  • 签到天数: 361 天
    发表于 2014-3-6 17:03:38 | 显示全部楼层 |阅读模式
    EV- VND5E025AK评估板预装配有VND5E025AK -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VND5E025AK provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VND5E025AK-E high-side driver.The VND5E025AK-E is a double channel high-side driver manufactured using ST proprietary VIPower M0-5 technology and housed in PowerSSO-24 package. The VND5E025AK-E is designed to drive 12 V automotive grounded loads, providing protection, diagnostics and easy 3 V and 5 V CMOS-compatible interface with any microcontroller.The device integrates advanced protective functions such as load current limitation, inrush and overload active management by power limitation, overtemperature shut-off with auto-restart and overvoltage active clamp. A dedicated analog current sense pin is associated with every output channel provides enhanced diagnostic functions including fast detection of overload and short-circuit to ground through power limitation indication, overtemperature indication, short-circuit to VCCdiagnosis and ON-state and OFF-state open-load detection.The current sensing and diagnostic feedback of the whole device can be disabled by pulling the CS_DIS pin high to share the external sense resistor with similar devices.
    EV-VND5E025AK Brief.pdf
    165.84 KB, 下载次数: 0
    VND5E025AK-E.pdf
    467.75 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:12 , Processed in 0.108060 second(s), 16 queries , MemCache On.
