查看: 228|回复: 0
EV- VNQ5E050K评估板
  • 签到天数: 361 天
    发表于 2014-3-6 16:45:45 | 显示全部楼层 |阅读模式
    EV- VNQ5E050K评估板预装配有VNQ5E050K -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VNQ5E050K provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VNQ5E050K-E high-side driver.The VNQ5E050K-E is a quad channel high-side driver manufactured using ST proprietary VIPower M0-5 technology and housed in PowerSSO-24 package. The VNQ5E050K-E is designed to drive automotive grounded loads, providing protection, diagnostics and easy 3 V and 5 V CMOS-compatible interface with any microcontroller.The device integrates advanced protective functions such as load current limitation, inrush and overload active management by power limitation, overtemperature shut-off with auto-restart and overvoltage active clamp. A dedicated active low digital status pin is associated with every output channel in order to provide enhanced diagnostic functions including fast detection of overload and short-circuit to ground, overtemperature indication, short-circuit to VCCdiagnosis and ON-state and OFF-state open-load detection.The diagnostic feedback of the whole device can be disabled by pulling the STAT_DIS pin up, thus allowing wired-ORing with similar devices.
    VNQ5E050K-E.pdf
    532.64 KB, 下载次数: 0
    EV-VNQ5E050K Brief.pdf
    166.59 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:25 , Processed in 0.124773 second(s), 16 queries , MemCache On.
