查看: 268|回复: 0
EV- VND5T035AK评估板
  • 签到天数: 361 天
    发表于 2014-3-6 16:13:17 | 显示全部楼层 |阅读模式
    EV- VND5T035AK评估板来预装配有VND5T035AK -E高端驱动器。为用户提供一个简单的方法来连接意法半导体的表面,安装半导体VIPower ®驱动程序到用户现有的原型电路。EV-VND5T035AK provides you an easy way to connect ST’s surface mounted VIPower®drivers into your existing prototype circuitry. This evaluation board comes pre-assembled with VND5T035AK-E high-side driver.The VND5T035AK-E is monolithic device made using STMicroelectronics®VIPower technology, intended for driving resistive or inductive loads with one side connected to ground. Active VCCpin voltage clamp protects the device against low energy spikes.The device integrates an analog current sense which delivers a current proportional to the load current.Fault conditions such as overload, overtemperature or short to VCCare reported via the current sense pin. Output current limitation protects the device in overload conditions. The device latches off in case of overload or thermal shutdown.The device is reset by a low level pass on the fault reset standby pin.A permanent low level on the inputs and on the fault reset standby pins disables all outputs and sets the device in standby mode.
    VND5T035AK-E.pdf
    712.27 KB, 下载次数: 0
    EV-VND5T035AK Brief.pdf
    165.62 KB, 下载次数: 0
    GMT+8, 2025-1-16 00:16 , Processed in 0.110985 second(s), 16 queries , MemCache On.
