查看: 269|回复: 0
STEVAL-TLL002V1评估板
  • 签到天数: 361 天
    发表于 2014-3-5 16:44:08 | 显示全部楼层 |阅读模式
    STEVAL-TLL002V1评估板是基于STCF01的闪存驱动器 。这是一个白光LED驱动器,用于驱动两个四个LED,从单节锂离子电池输入进同时也进行了优化。This evaluation board is based on the STCF01, that is a white LED driver optimized for driving two to four LEDs from a Li-Ion battery input.It provides up to 300 mA over an input voltage range of 2.6 V to 5.5 V and it features 16.5 V output voltage, 1.5 MHz internal power switch, internal soft start, open load voltage protection and optimized internal compensation.Only an inductor, a Schottky diode, two capacitors and two resistors are required. Besides, a low output ripple is guaranteed by the current mode PWM topology and by the use of low E.S.R. SMD ceramic capacitors The STCF01 is ideal for camera flash in cellular phones requiring, small circuit size and very high efficiency (up to 90%).
    STEVAL-TLL002V1 Data Brief.pdf
    89.5 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:43 , Processed in 0.109891 second(s), 16 queries , MemCache On.
