查看: 308|回复: 0
STEVAL-PCC001V1评估套件
  • 签到天数: 361 天
    发表于 2014-3-5 16:03:29 | 显示全部楼层 |阅读模式
    STEVAL-PCC001V1评估套件演示了如何使用USB全速ST72651微控制器,作为USB和RS232接口之间的桥梁,提供配备USB的电脑上增加了一个串口。此外,该评估套件需要专用的驱动程序来演示USB ST72651微控制器连接到PC。This evaluation kit demonstrates the use of the USB full-speed microcontroller ST72651 as a bridge between the USB and the RS232 interface, providing an additional serial port on computers equipped with USB. In addition, this evaluation kit demonstrates a simple method for connecting the USB microcontroller ST72651 to the PC without need of a proprietary driver. Several generalpurpose input/output pins of the ST72651 are provided on the external connector, thus providing a way to connect additional circuitry and allow customized USB applications. The evaluation board can be reprogrammed easily with a user code through the in-circuit communication (ICC) connector.
    STEVAL-PCC001V1 Data Brief.pdf
    80.15 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:06 , Processed in 0.127694 second(s), 16 queries , MemCache On.
