查看: 302|回复: 0
STEVAL- PCC009V1演示板
  • 签到天数: 361 天
    发表于 2014-3-5 15:28:38 | 显示全部楼层 |阅读模式
    STEVAL- PCC009V1演示板实现了一个基于STM32的一个普遍的USB转串行通信接口( UUSCI ) 。该演示板有一个10针的接口。This demonstration board implements an universal USB to serial communication interface (UUSCI) based on STM32.This demoboard has a 10 pin interface. In this interface, there is a provision to connect a device which can communicate using I2C, SPI and UART. Thus UUSCI tool allows a user to connect a serial communication based device to a PC. At the same time it allows to control some GPIOs available in that 10 pin interface and set them in input/output modes as per the application requirements.In UUSCI demonstration board, the STM32 microcontroller is used as the interface between PC and the end device. Due to intelligence available in the STM32 device, I2C, SPI and UART are multiplexed in same 10 pin interface thus leading to reduced board size and the complexity of usage.Power to board is provided from USB Mini B-Type connector.DLL files of the PC GUI are provided with this tool. So a user can use these DLL files to make their own customized PC GUI as per their requirements.
    STEVAL-PCC009V1 Data Brief.pdf
    327.79 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:36 , Processed in 0.120230 second(s), 16 queries , MemCache On.
