查看: 204|回复: 0
STEVAL-PCC009V2演示板
  • 签到天数: 361 天
    发表于 2014-3-4 16:42:23 | 显示全部楼层 |阅读模式
    STEVAL-PCC009V2演示板实现了一个IBU通用接口(IBUUI),这是一个STM32x型USB转串口桥组成的一个可配置的10-pin接口和30针接口。The STEVAL-PCC009V2 board implements an IBU universal interface (IBUUI), which is an STM32x-based USB-to-serial interface bridge consisting of a configurable 10-pin interface and a 30-pin interface.The STM32x microcontroller is used as an interface between the PC and another end system. Various communication peripherals are multiplexed with GPIOs, ADC and PWM channels in both the 10-pin and 30-pin interfaces.With these interfaces, there is a provision to connect a device which can communicate using I2C, SPI and UART. Thus, the IBUUI tool allows users to connect a serial communication-based device to a PC. At the same time, it allows user control of some GPIOs available in 10-pin and 30-pin interfaces, and sets them to input/output mode as per application requirements.
    STEVAL-PCC009V2 Data Brief.pdf
    135.48 KB, 下载次数: 0
    STEVAL-PCC009V2 Use Manual.pdf
    1.96 MB, 下载次数: 0
    GMT+8, 2025-1-16 01:51 , Processed in 0.116893 second(s), 16 queries , MemCache On.
