查看: 338|回复: 0
STEVAL-ISB009V1演示板
  • 签到天数: 361 天
    发表于 2014-3-4 14:42:28 | 显示全部楼层 |阅读模式
    STEVAL-ISB009V1演示板,基于STC3100,能够监控一个单节锂离子电池(电压,温度和电流)的关键参数,包括硬件功;也能实现气体压力表,适用于电池充电监控,基于一个可编程的12位至14位A/ D转换器。The STEVAL-ISB009V1 demonstration board, based on the STC3100, is able to monitor the critical parameters of a single-cell Li-Ion battery (voltage, temperature, and current) and includes hardware functions to implement a gas-gauge for battery charge monitoring, based on a programmable 12-bit to 14-bit A/D converter.The battery current can be up to 2.5 A and the accumulator system provides a capacity up to +/-7000 mAh with a resolution of 0.2 mAh.The device is programmable through an I2C interface.
    STC3100.pdf
    278.62 KB, 下载次数: 0
    STEVAL-ISB009V1 App Note.pdf
    414.47 KB, 下载次数: 0
    STEVAL-ISB009V1 Data Brief.pdf
    87.55 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:05 , Processed in 0.115116 second(s), 16 queries , MemCache On.
