查看: 281|回复: 0
EVAL6470H演示板
  • 签到天数: 361 天
    发表于 2014-3-4 14:15:26 | 显示全部楼层 |阅读模式
    EVAL6470H演示板是一个完全集成的微电机驱动。与STEVAL-PCC009V2通讯板和dSPIN评估软件相结合,此板允许用户调查L6470设备的所有功能。特别是,该板可用于检查电压模式驱动,为了适应不同的应用需求来调节L6470参数。The EVAL6470H demonstration board is a fully integrated microstepping motor driver. In combination with the STEVAL-PCC009V2 communication board and the dSPIN evaluation software, the board allows the user to investigate all the features of the L6470 device. In particular, the board can be used to check the voltage mode driving and to regulate the L6470 parameters in order to fit the application requirements.The EVAL6470H supports the daisy-chain configuration making it suitable for the evaluation of the L6470 in multi-motor applications.
    EVAL6470H Brief.pdf
    1.72 MB, 下载次数: 0
    L6470.pdf
    738.29 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:43 , Processed in 0.115933 second(s), 16 queries , MemCache On.
