查看: 256|回复: 0
EVAL6472H演示板
  • 签到天数: 361 天
    发表于 2014-3-4 14:10:05 | 显示全部楼层 |阅读模式
    EVAL6472H演示板是一个完全集成的微电机驱动。与STEVAL-PCC009V2通讯板和dSPIN评估软件相结合,此板允许用户调查L6472设备的所有功能。特别是,该板可用于以适应,应用需求来调节L6472参数。The EVAL6472H demonstration board is a fully integrated microstepping motor driver. In combination with the STEVAL-PCC009V2 communication board and the dSPIN evaluation software, the board allows the user to investigate all the features of the L6472 device. In particular, the board can be used to regulate the L6472 parameters in order to fit application requirements.The EVAL6472H supports the daisy chain configuration making it suitable for the evaluation of the L6472 in the multi-motor applications.
    EVAL6472H.pdf
    1.15 MB, 下载次数: 0
    GMT+8, 2025-1-16 01:44 , Processed in 0.109696 second(s), 16 queries , MemCache On.
