查看: 400|回复: 0
EVAL6472PD演示板
  • 签到天数: 361 天
    发表于 2014-3-4 14:05:16 | 显示全部楼层 |阅读模式
    EVAL6472PD演示板是一个完全集成的微电机驱动。与STEVAL-PCC009V2通讯板和dSPIN评估软件相结合,此板允许用户调查L6472设备的所有功能。The EVAL6472PD demonstration board is a fully integrated microstepping motor driver. In combination with the STEVAL-PCC009V2 communication board and the dSPIN evaluation software, the board allows the user to investigate all the features of the L6472 device. In particular, the board can be used to regulate the L6472 parameters in order to fit application requirements.The 4-layer layout and the PowerSo package allow the top thermal performance to be obtained.The EVAL6472PD supports the daisy chain configuration making it suitable for the evaluation of the L6472 in the multi-motor applications.
    L6472.pdf
    1.33 MB, 下载次数: 0
    GMT+8, 2025-1-16 01:39 , Processed in 0.116134 second(s), 16 queries , MemCache On.
