查看: 220|回复: 0
STEVAL-IPE016V1演示板
  • 签到天数: 361 天
    发表于 2014-3-4 13:53:12 | 显示全部楼层 |阅读模式
    STEVAL-IPE016V1单相电能计量演示板具有一个基于该STPM10电流互感器和一个分流电阻。The STEVAL-IPE016V1 demonstration board is a class 0.5, single-phase microprocessor-based meter with tamper detection for power line systems of Vnom = 140 to 300 VRMS, Inom/Imax = 2/20 ARMS, flin = 45 to 65 Hz and Tamb = -40 to +85°C.The tamper detection feature implements one current transformer and one shunt resistor to monitor the live and neutral wire currents.The STEVAL-IPE016V1 demonstration board has a 10-pin connector to be interfaced to a microcontroller or to a PC through a parallel or serial programmer for reading data.
    STEVAL-IPE016V1 Brief.pdf
    161.61 KB, 下载次数: 0
    STPM10.pdf
    565.16 KB, 下载次数: 0
    STEVAL-IPE0xxV1 User Manual.pdf
    388.98 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:06 , Processed in 0.105459 second(s), 16 queries , MemCache On.
