查看: 386|回复: 0
STEVAL-IFN002V1评估板
  • 签到天数: 361 天
    发表于 2014-3-3 14:19:57 | 显示全部楼层 |阅读模式
    STEVAL-IFN002V1评估板的设计是基于一个强大的ARM7TDMI内核的32位微控制器STR730F。This evaluation board is designed with a 32-bit STR730F microcontroller based on a powerful ARM7TDMI core. The STR730F provides an extensive number of peripheral functions and enhanced I/O capabilities as it is equipped with RS-232, RS-485, CAN, SPI, I²C and JTAG communication interfaces. This board is suitable for industrial applications and can be used, in particular, as a reference design for the development of the programmable logic controller (PLC) section in factory automation. This solution is implemented on a double-faced board with two copper layers only for increased costeffectiveness.
    STEVAL-IFN002V1 Data Brief.pdf
    208.59 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:06 , Processed in 0.118034 second(s), 16 queries , MemCache On.
