查看: 419|回复: 0
打印 上一主题 下一主题
EVL6564H-100W演示板
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-3-3 13:58:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    EVL6564H-100W演示板是基于新的过渡模式PFC控制器L6564H,并实现了100瓦,宽范围电源输入,PFC预调节器适用于镇流器,适配器,平面显示器,并具有满足所有SMPS IEC61000-3- 2或JEITA - MITI规定。This demonstration board is based on the new transition-mode PFC controller L6564H and implements a 100 W, wide-range mains input, PFC pre-conditioner suitable for ballast, adapters, flat screen displays, and all SMPS having to meet IEC61000-3-2 or JEITA-MITI regulations.The L6564H is a current-mode PFC controller operating in transition mode (TM) which embeds the same features existing in the L6564 with the addition of a high voltage startup source. These functions make the IC especially suitable for applications that must be compliant with energy saving regulations and where the PFC preregulator works as the master stage.The EVAL6564H-100W implements a power factor correction (PFC) pre-regulator 100 W, continuous power, on a regulated 400 V rail from a wide-range mains voltage and providing for the reduction of the mains harmonics, allowing the European EN61000-3-2 or the Japanese JEITAMITI standard to be met. The regulated output voltage is typically the input for the cascaded isolated DC-DC converter that provides the output rails required by the load.
    L6564H.pdf
    1.63 MB, 下载次数: 0
    EVL6564H-100W Brief.pdf
    100.51 KB, 下载次数: 0
    举报
    站长推荐上一条 3/5 下一条
    【预约|参会享"豪"礼】2025慕尼黑上海设备展
    查看 »
    GMT+8, 2025-4-30 04:38 , Processed in 0.110452 second(s), 18 queries , MemCache On.
