查看: 270|回复: 0
打印 上一主题 下一主题
SPV1040 太阳能电池演示版
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-3-3 13:23:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    STEVAL-ISV006V2演示板是基于嵌入式MPPT的SPV1040高效率的太阳能电池充电器。该SPV1040设备是一款低功耗,低电压,单片升压转换器,输入电压范围为0.3 V至5.5 V,能够通过最大化,甚至一个单一的太阳能电池(或燃料电池)所产生能量。The STEVAL-ISV006V2 demonstration board is based on the SPV1040 high efficiency solar battery charger with embedded MPPT. The SPV1040 device is a low power, low voltage, monolithic step-up converter with an input voltage range from 0.3 V to 5.5 V, and is capable of maximizing the energy generated by even a single solar cell (or fuel cell), where low input voltage handling capability is extremely important.Thanks to the embedded MPPT algorithm, even under varying environmental conditions (such as irradiation, dirt, temperature) the SPV1040 offers maximum efficiency in terms of power harvested from the cells and transferred to the output.The device employs an input voltage regulation loop, which fixes the charging battery voltage via a resistor divider. The maximum output current is set with a current sense resistor according to charging current requirements.
    STEVAL-ISV006V2 Appl Note (AN3319).pdf
    1.11 MB, 下载次数: 0
    SPV1040.pdf
    965.54 KB, 下载次数: 0
    STEVAL-ISV006V2 Brief.pdf
    294.27 KB, 下载次数: 0
    举报
    站长推荐上一条 3/5 下一条
    【预约|参会享"豪"礼】2025慕尼黑上海设备展
    查看 »
    GMT+8, 2025-4-30 09:01 , Processed in 0.112068 second(s), 18 queries , MemCache On.
