查看: 231|回复: 0
STEVAL-MKI117V2演示板
  • 签到天数: 361 天
    发表于 2014-2-28 16:15:12 | 显示全部楼层 |阅读模式
    STEVAL-MKI117V2演示板的目的是提供一种数字MEMS麦克风输出的解码和流的一个例子。该STEVAL-MKI117V2演示板承载MP45DT02(顶部端口数字麦克风),并且在STM32F107RC微控制器下工作,作为一个传感器或一个音频解码器。The purpose of the STEVAL-MKI117V2 demonstration board is to provide an example of the decoding and streaming of digital MEMS microphone outputs.The STEVAL-MKI117V2 demonstration board hosts the MP45DT02 (top-port digital microphone), working as a sensor, and the STM32F107RC microcontroller, working as an audio decoder.These microphones are analog-to-digital transducers, in other words, they are able to sense sound pressure and convert this signal into a digital signal using the PDM technique.The STM32 microcontroller decodes the PDM signal coming from the microphones and streams the audio via the USB.The STEVAL-MKI117V2 demonstration board is a sound card automatically recognized by the PC as an audio device. The connection is made through a USB cable which also supplies the board and then streams the collected audio.
    STEVAL-MKI117V2 Brief.pdf
    348.28 KB, 下载次数: 0
    MP45DT02.pdf
    356.88 KB, 下载次数: 0
    STM32F105xx/7xx Datasheet.pdf
    1.83 MB, 下载次数: 0
    GMT+8, 2025-1-16 01:51 , Processed in 0.126080 second(s), 16 queries , MemCache On.
