查看: 205|回复: 0
STEVAL-IPE015V1演示板
  • 签到天数: 361 天
    发表于 2014-2-28 15:38:21 | 显示全部楼层 |阅读模式
    STEVAL-IPE015V1演示板是一个0.5级,是在STPM10两个电流互感器的基础上的单相电能计量演示板。The STEVAL-IPE015V1 demonstration board is a class 0.5, single-phase microprocessor-based meter with tamper detection for power line systems of Vnom = 140 to 300 VRMS,Inom / Imax = 2/20 ARMS, flin = 45 to 65 Hz and Tamb = -40 to +85 °C.A stepper motor display shows the values of the energy measured by the standalone meter.The tamper detection feature implements two current transformers which monitor the live and neutral wire currents.The STEVAL-IPE015V1 demonstration has a 10-pin connector to be interfaced to a microcontroller or to a PC through a parallel or serial programmer for reading data.
    STEVAL-IPE015V1 Brief.pdf
    174.36 KB, 下载次数: 0
    STEVAL-IPE0xxV1 User Manual.pdf
    388.98 KB, 下载次数: 0
    STPM10.pdf
    565.16 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:36 , Processed in 0.118646 second(s), 16 queries , MemCache On.
