查看: 395|回复: 0
STEVAL-ILB008V1照明镇流器
  • 签到天数: 361 天
    发表于 2014-2-28 15:02:06 | 显示全部楼层 |阅读模式
    STEVAL-ILB008V1是一个大范围的照明镇流器,可驱动4×18 W线性T8荧光灯管。镇流器是基于L6585DE芯片,它集成了PFC和半桥控制电路,并管理所有的灯操作阶段(预热,点火和运行模式)所需的电路控制。The STEVAL-ILB008V1 is a wide-range lighting ballast capable of driving 4 x 18 W linear T8 fluorescent tubes.The ballast is controlled by the L6585DE IC, which integrates PFC and half-bridge control circuits, relevant drivers, and the circuitry required to manage all lamp operating phases (preheating, ignition and run mode). Protection against failures such as lamp disconnection, anticapacitive mode, and PFC overvoltage are guaranteed and achieved using a minimum number of external components.An electronic ballast consumes less power and therefore dissipates less heat than an electromagnetic ballast. The energy saved is estimated to be in the range of 20-25% for a given lamp power. Moreover, an electronic solution allows for improved control of the filament current and lamp voltage during pre-heating, resulting in increased lamp life.
    STEVAL-ILB008V1 App Note.pdf
    692.47 KB, 下载次数: 0
    STEVAL-ILB008V1 Data Brief.pdf
    110.84 KB, 下载次数: 0
    L6585DE.pdf
    2.02 MB, 下载次数: 0
    GMT+8, 2025-1-16 01:47 , Processed in 0.115365 second(s), 16 queries , MemCache On.
