查看: 292|回复: 0
STEVAL-IHM010V1演示板
  • 签到天数: 361 天
    发表于 2014-2-27 16:14:24 | 显示全部楼层 |阅读模式
    STEVAL-IHM010V1演示板是一个完整的开发平台 。该STEVAL-IHM010V1在ST7MCx基础上具有发展的外设电机控制应用,包括电机控制外设(MTC)和串行通信接口(SCI),一个电机控制接口和硬件功能。The STEVAL-IHM010V1 demonstration board is a complete development platform for STMicroelectronics' 8-bit ST7MCx microcontroller with 16 KB internal Flash memory. Based on a cost-effective, flexible and open design, the board helps demonstrate the ST7MCx's capabilities and enables rapid evaluation of the microcontroller's motor-control peripherals.The STEVAL-IHM010V1 has a motor-control connector and hardware features for developing motor control applications based on ST7MCx peripherals, including the motor-control peripheral (MTC) and serial communication interface (SCI). In addition, it uses an in-circuit communication (ICC) standard interface to connect to a host PC via in-circuit debuggers/programmers such as the inDART-STX board from Softec.
    STEVAL-IHM010V1 Data Brief.pdf
    138.64 KB, 下载次数: 0
    STEVAL-IHM010V1 User Manual.pdf
    838.68 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:52 , Processed in 0.109177 second(s), 16 queries , MemCache On.
