查看: 259|回复: 0
STEVAL-IHT006V1演示板
  • 签到天数: 361 天
    发表于 2014-2-27 14:37:26 | 显示全部楼层 |阅读模式
    STEVAL- IHT006V1是一种低成本的演示板,家电市场运用普遍。很适合取代机械式温控器和白炽灯泡的家用冰箱。The STEVAL-IHT006V1 is a low-cost demonstration board for the home appliance market. It is suitable to replace the mechanical thermostat and the incandescent light bulb in domestic refrigerators.The system employs the 8-bit STM8S103F2 microcontroller running at 16 MHz and featuring 4 kB of Flash memory, a 10-bit A/D converter,8/16-bit timers, communication interfaces and 640 bytes EEPROM.The power supply circuitry is based on the VIPer16L, an offline converter with an 800 V avalanche-rugged power section, operating at 60 kHz.The STEVAL-IHT006V1 is designed to drive small-size or mid-size compressors up to 200 W using the ACST8, an 8 A 800 V overvoltage-protected AC switch.Three 100 mA LEDs efficiently replace a 15 W incandescent light bulb.The demonstration board has passed the internal tests for EMC directives: IEC 61000-4-4 (burst up to 8 kV) and IEC 61000-4-4 (surge up to 2 kV).In standby mode, the STEVAL-IHT006V1 has a standby power consumption below 170 mW at 220 VAC 50 Hz.
    GMT+8, 2025-1-16 01:44 , Processed in 0.114130 second(s), 15 queries , MemCache On.
