查看: 262|回复: 0
STEVAL-IKM001V1开发套件
  • 签到天数: 361 天
    发表于 2014-2-27 14:18:04 | 显示全部楼层 |阅读模式
    STEVAL-IKM001V1开发套件是1个EVAL6470H评估板+1个STEVALPCC009V2通讯板,每个ST的L6470H和L6470PD设备的2个样本组成的套件。该EVAL6470H评估板是一个完全集成的微电机驱动。The STEVAL-IKM001V1 is a kit composed of 1 EVAL6470H evaluation board + 1 STEVALPCC009V2 communication board, and 2 samples each of ST’s L6470H and L6470PD devices.The EVAL6470H evaluation board is a fully integrated microstepping motor driver. In combination with the STEVAL-PCC009V2 communication board and the dSPIN evaluation software, the board allows the user to evaluate all the features of the L6470 device. In particular, the board can be used to check voltage mode driving and to regulate the L6470H parameters in order to meet application requirements.The EVAL6470H supports the daisy-chain configuration, making it suitable for valuation of the L6470 in multi-motor applications.
    STEVAL-IKM001V1 Data Brief.pdf
    79.17 KB, 下载次数: 0
    L6470.pdf
    738.29 KB, 下载次数: 0
    GMT+8, 2025-1-16 01:35 , Processed in 0.108628 second(s), 16 queries , MemCache On.
