查看: 211|回复: 0
STEVAL-PCC011V1演示板
  • 签到天数: 361 天
    发表于 2014-2-26 17:14:01 | 显示全部楼层 |阅读模式
    STEVAL-PCC011V1演示板被设计成一个评估平台ST802RT1B,快速以太网物理层(PHY)接口,支持100BASE-FX应用。该PHY提供了媒体独立接口(MII),并减少媒体独立接口(RMII),便于附接至10/100介质接入控制器(MAC)。The STEVAL-PCC011V1 demonstration board is designed as an evaluation platform for the ST802RT1B, Fast Ethernet physical layer (PHY) interface supporting 100BASE-FX applications. The PHY provides a media independent interface (MII) and reduced media independent interface (RMII) for easy attachment to 10/100 media access controllers (MAC).Many jumpers, test points and connectors on the demonstration board allow testing of the features provided by the ST802RT1B Ethernet PHY.An additional header connector allows connection to the STM32F107 controller demonstration board (not included with the STEVAL-PCC011V1), providing the capability for quick evaluation of the complete application – microcontroller and the physical layer.
    STEVAL-PCC011V1 Demo Brd.pdf
    120.79 KB, 下载次数: 0
    ST802RT1A/B.pdf
    584.27 KB, 下载次数: 0
    STEVAL-PCC011V1 User Manual.pdf
    1.05 MB, 下载次数: 0
    GMT+8, 2024-11-25 23:31 , Processed in 0.109260 second(s), 16 queries , MemCache On.
