查看: 254|回复: 0
STEVAL-ISQ009V1演示板
  • 签到天数: 361 天
    发表于 2014-2-26 15:29:34 | 显示全部楼层 |阅读模式
    STEVAL-ISQ009V1演示板是由三个相同的部分(子板)和主板组成。The STEVAL-ISQ009V1 demonstration board is composed of three identical sections (daughterboards) and a motherboard.Each daughterboard is capable of performing DCDC conversion starting from +5 VDC and is designed to deliver 3.3 V / 5 A to the load.The input terminals of the motherboard are connected to a +5 VDC external source and the output terminals to the load. The board can accommodate up to three DC-DC converters.The motherboard contains the circuitry necessary to perform current sharing (utilizing the L6615) and to isolate a failed section from the load. It is designed to be adaptable to all power supplies (compatible with the L6615 absolute maximum ratings) having remote sense pins. By changing just a few components, it can be modified for new specifications.
    STEVAL-ISQ009V1 Data Brief.pdf
    149.9 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:07 , Processed in 0.122564 second(s), 16 queries , MemCache On.
