TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
STEVAL-IAC001V1评估板是一个完整的参考系统解决低/中端的安全区段。 它是一种基于总线网络上的一个完整的硬件和软件报警平台。The Central Unit for Alarm System (CUAS) Evaluation Board is a complete reference system addressing the low/middle end security segment.It is a complete hardware and software alarm platform based on BUS network. The whole system consists of four boards: CU board, CM (Control Module) board, PS (Power Supply) board and PC interface board. There is also a PC GUI software which could be easily used in order to set up all the CU parameters and execute certain system tests.It is possible to expand the system using I/O Expansion boards (Inputs and Outputs expansion), a GSM board, which the connector is already in the CU Board (for the CU management through a GSM telephone) and other modules such as RF-ID, smart-card or Keyboard connected through the BUS. |
