查看: 420|回复: 0
STEVAL-IPC001V1评估板
  • 签到天数: 361 天
    发表于 2014-2-25 16:24:43 | 显示全部楼层 |阅读模式
    STEVAL-IPC001V1是一个集成系统,使设计人员能够评估一个完整的,并准备使用的收银机的应用。它是为低到中端POS机/收款机市场,由硬件电路板,固件和PC的GUI(图形用户界面)。The STEVAL-IPC001V1 is an integrated system to allow designers to evaluate a complete and ready-to-use cash register application. It is intended for the low to medium-end POS/cash register market and consists of a hardware board, firmware and PC GUI (graphical user interface).At the core of the board, the STR710FZ2 microcontroller controls all tasks of the system.The STR710FZ2 gives the board a wide scope of communication capabilities, incorporating four UARTs, one 10T-LAN, one PS/2 interface and various IC and SPI connectors. The firmware is a modular suite which simultaneously implements a typical cash register application and provides a suitable library to develop an optimized and customized final application.
    STEVAL-IPC001V1 Data Brief.pdf
    181.34 KB, 下载次数: 0
    GMT+8, 2024-11-25 23:18 , Processed in 0.106183 second(s), 16 queries , MemCache On.
