查看: 315|回复: 0
STM32100B-MCKIT入门套件
  • 签到天数: 361 天
    发表于 2014-2-25 16:18:21 | 显示全部楼层 |阅读模式
    STM32100B-MCKIT入门套件是设计来提供一个集成系统周围的意法半导体微控制器STM32F100开发完成,准备使用的电机控制应用。该入门套件特别适合于驱动三相无刷永磁同步电机,并演示了如何有效的低成本微控制器STM32F100,可以在成本优化的现实世界的电机控制应用中使用。The STM32100B-MCKIT starter kit is an integrated system designed to provide a complete, ready-to-use motor control application developed around the STMicroelectronics STM32F100 microcontroller. This starter kit is particularly suited to drive three-phase brushless permanent magnet synchronous motors and demonstrates how effectively the low-cost STM32F100 microcontrollers can be used in cost optimized real-world motor control applications.The STM32100B-MCKIT supports Field Oriented Control (FOC) drive of three-phase permanent magnet synchronous motors (PMSM). Singleshunt resistor current measurement is supported out-of-the-box allowing closed loop torque control. Position measurement can be implemented using quadrature encoder sensors, Hall effect sensors or sensorless algorithms.
    STM32100B-MCKIT Brief.pdf
    50.74 KB, 下载次数: 0
    STM32100B-MCKIT User Manual.pdf
    127.41 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:59 , Processed in 0.122169 second(s), 16 queries , MemCache On.
