查看: 1196|回复: 0
EVAL6470H-DISC开发工具
  • 签到天数: 361 天
    发表于 2014-2-25 15:08:21 | 显示全部楼层 |阅读模式
    EVAL6470H-DISC dSPIN™Discovery是一款低成本开发工具,以探索dSPIN™(L6470)电机驱动器为主要目的。对于为初学者和有经验的用户,它是一个理想的启动套件。它自主性强,可以用一个软件界面或以嵌入式微控制器的自定义固件。The dSPIN™ Discovery is a low cost development tool to explore the dSPIN™ (L6470)motor driver.An ideal starter-kit for both beginners and experienced users, it is autonomous and can be used with a software interface or with a custom firmware thanks to the embedded microcontroller.Through the available GUI the user can easily set the full configuration of application parameters. “Plug and Play” tool it offers high motor control flexibility thanks to the wide operating voltage range from 8 V to 45 V and the current capability up to 3 Ar.m.s . It is equipped with LED indicators for specific ready, busy, error warning.
    EVAL6470H-DISC Data Brief.pdf
    1.39 MB, 下载次数: 0
    L6470.pdf
    738.29 KB, 下载次数: 0
    GMT+8, 2025-1-16 02:39 , Processed in 0.111706 second(s), 16 queries , MemCache On.
